- Thank you received: 6
Another CV 'O' ring question - KZ440
- mwriders
- if I only had a brain
04 Oct 2010 12:11 #404008
by mwriders
1980 Kawasaki KZ440B (brand new eBaby)
1998 Ducati 900S (gone)
1978 BMW R100S (gone, damn it)
1975 Yamaha RD350 cafe (gone)
1986 Yamaha XJ650 Seca (gone)
1981 Kawasaki KZ440LTD (gone)
1969 HD Sportster (gone
1966 Honda CB160 (gone, damn it)
1965 Suzuki 80
Another CV 'O' ring question - KZ440 was created by mwriders
In rebuilding the CV carbs on my 1980 KZ440B, it became obvious that the last person to work on them never replaced an 'O' ring. Looking at the line drawings for these carbs, I see an 'O' ring specified for the plastic plug (the purpose of which I do not know). When I pulled those plugs out, there were again no 'O' rings. So far, I've just assumed that the book was right and the last tinkerer wrong. This time, I even have two small 'O' rings leftover from my rebuild kit, and kind of imagine that this is where they belong.
My question is, does anyone know better, or can somebody assure me that the two 'O' rings in the rebuild kit are indeed meant to tip those plastic plugs? Thanks.
1965 Suzuki 80
- TeK9iNe
- What did you do!?!
- Thank you received: 28
04 Oct 2010 13:29 #404033
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Another CV 'O' ring question - KZ440
The plugs are o-ringed to prevent fuel from leaking past.
I believe that plug is part of the pilot fuel circuit, preventing the pilot from recieving too much un-metered fuel.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- JR
- Thank you received: 449
04 Oct 2010 19:43 #404094
by JR
Replied by JR on topic Another CV 'O' ring question - KZ440
+1
The same type of plug is in the CV 34 carbs for the 750 and you need the o ring on that plug. It covers the pilot jet which gets its gas via a line off the primary main jet.
- MFolks
- Thank you received: 540
04 Oct 2010 21:00 #404102
by MFolks
Replied by MFolks on topic Another CV 'O' ring question - KZ440
My list of carb part websites:
www.nrp-carbs.com
www.motorcyclecarbs.com
www.carbparts.com
www.carbkitscapital.com
www.pjmotorsports.com
www.jetsrus.com
www.sportingforless.com/servlet/the-Carb-repair-kit/Categories
www.oldbikebarn.com/Motorcycle_Parts/Carb-Rebuild-Kit
www.cycleorings.com/
www.nrp-carbs.com
www.carbparts.com
www.jetsrus.com
- mwriders
13 Oct 2010 11:28 #406361
by mwriders
1965 Suzuki 80
Replied by mwriders on topic Another CV 'O' ring question - KZ440
So, are those 'O' rings routinely included in rebuild kits? I'm hoping so, because otherwise I have 2 leftover (no carb genius here). I'm concerned that I can screw the process up totally if they're not supposed to go there. Thanks.
1965 Suzuki 80
