- Thank you received: 2
Carbs and new coils questions
- KZ1979LTD
carbs: stock as far as I can tell
Stock airbox
Header: 4 into 1 Yosh with baffle
I did not make any changes to the carbs after installing the Yosh. (previously had the stock Jardine 2 into 1's) Have some popping on deceleration. Bought new ACCEL high output coils to install in hopes of converting over to Dyna electronic ignition soon.
The paperwork with the coils says these coils have such a hotter spark that "larger jet sizes could be needed in order to maximize power output and prevent a possible lean fuel condition that might damage the engine".
Question is: Does this sound right to you guys, and if so how much bigger should I go on the jet sizes?
thanks for the input, Tom
- bountyhunter
- Thank you received: 337
That sounds like a giant crock of marketing hooey suitable for fertilizing plants. You need a proper spark to get maximum power, but a "hotter" spark won't buy anything assuming the stock ignition is adequate for the job and most are. If you replace a failing coil with a new one, you would see an increase in power.Bike: 1979 KZ 1000 LTD
Stock airbox
If you hear popping on decel, it probably is lean but due to high flow of headers not ignition.
Popping can also be caused by exhaust leaks at the headers. Are the exhaust gaskets sealing tight?
- KZ1979LTD
- bountyhunter
