KZ750 four w/ RS34 Mikuni Carbs hitting Tensioner
- racerock
02 Oct 2010 06:30 - 03 Oct 2010 10:01 #403333
by racerock
KZ750 four w/ RS34 Mikuni Carbs hitting Tensioner was created by racerock
Picked up a set of RS34's for my 81 KZ750. Thanks go Beefsquasher for looking at the bike and bench synching the carbs.
SO, I go to mount them and one of the carbs hits the chain tensioner. This one is the larger one with the large tensioner cap in addition to the smaller bolt...
www.cmsnl.com/kawasaki-1983-kz750-l3_mod...partslist/19166.html
Should I go to a manual tensioner (APE)?
Or stick with the older tensioner?
My thought is manual tensioner.
Last edit: 03 Oct 2010 10:01 by racerock.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
02 Oct 2010 07:32 - 02 Oct 2010 07:34 #403353
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic KZ750 four with Mikini Carbs - hitting Tensioner
Those particular year auto-tentioners actually worked quite well if maintained, so either one you can manage to fit will work fine.
I gotta say though... RS34s are pretty huge for a 750. You may find them quite difficult to get "just right".
Do it, just DO IT.
Do it, just DO IT.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 02 Oct 2010 07:34 by TeK9iNe.
- racerock
03 Oct 2010 10:06 #403762
by racerock
Replied by racerock on topic KZ750 four w/ RS34 Mikuni Carbs hitting Tensioner
Hmm.. well before I go through the effort of getting these on (nothing is on it now)... would appreciate feedback on this.
Bike is basically stock internals, except for 4 into one V&H exhaust and K&N's. I know these are not serious mods - but they were there when I picked it up from a friend.
According to Mikuni the RS34's are what they recommend for this setup:
www.sudco.com/mikuni6.html
I have the stock carbs (or at least I think they are, and the PO had a shop try to get them to run right.
In the end, I just want this thing to start up nicely, run well, and not break down...
I'd appreciate feedback.
