Strange cold start and idle
- kloneil
17 Apr 2006 10:01
:huh: Got the 83 KZ750 Spectre out for a spin. It usually cold starts best with no choke and lots of juice. Then after a 5 minute warm up I have to put aobut 1/4 to 1/2 choke on her to get smooth above 4-5,000 RPM. Then I have to leave the choke in that position. It seems to be lean at cold start and then rich at warm up. But really I'm just guessing.
Any ideas?
Any ideas?
- KZ_Rage
- Kentucky Bourbon Barrel Ale
Re: Strange cold start and idle
17 Apr 2006 15:52
Dirty jets, improper float height, choke malfunctioning, etc...
If your starting it without a choke when cold, it is rich not lean, if you have to up the choke when hot then it is lean. I can only guess as to why you get a rich mixture when you open the throttle as it should supply the correct fuel/air mixture for the throttle position.
Is this something new or has this been the problem since you've had the bike? What happens when you use the choke when cold/
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
