- Thank you received: 5
Carb Boring
- dshelly
26 Sep 2010 05:29 #401882
by dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Replied by dshelly on topic Carb Boring
If you are going to bore out your carbs,you must have a way to get the slides farther down in the bore. Otherwise the bike won't idle down past 2500 rpm because the slide will bottom out on the recess in the bottom of the bore and leave to large of a gap.
I just bored out a set of 26mm to 29.5 , I made a special cutter to cut the seat where the slide sits.
When you cut the seat ,don't go too deep or you will cut right through into the bowl. These are pretty tricky to do.
You also have to move the clip position,since the slide sits lower in the bore. I put mine on my 76 900Ltd and it runs great!
Good luck.
Good luck.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- Thank you received: 797
27 Sep 2010 13:37 #402271
by 531blackbanshee
Replied by 531blackbanshee on topic Carb Boring
i had heard that when boring carbs that you have to offset the bore(up) a little to keep from breaking through.do you (dshelly)know if this is true?
- Becker
- The Doctor Will Rise Again
- Thank you received: 1
28 Sep 2010 16:48 #402543
by Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
Replied by Becker on topic Carb Boring
Awesome. I'm glad someone else has done this. What type of cutter and machine did you use??
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
