what other bikes can i get carbs from
- fochtup1
24 Sep 2010 14:00 #401476
by fochtup1
what other bikes can i get carbs from was created by fochtup1
hi, i'm looking to swap out my cv carbs on my kz 1100 shaft for non cv carbs. does anyone know what bikes i can rape for this? i know that i will probably need to re-jet the carbs and may need a push-pull throttle and cables.
justin
justin
- Nebr_Rex
- Thank you received: 300
24 Sep 2010 16:28 #401492
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic what other bikes can i get carbs from
Earlier Mikuni VM series KZ900/1000 and 2 valve GS750,850 and 1000 have the right carb spacing.You will need to use the earlier carb boots.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- fochtup1
24 Sep 2010 17:59 #401510
by fochtup1
Replied by fochtup1 on topic what other bikes can i get carbs from
ok cool, the junk yard has a bunch of different bikes, but did not want to waste money getting the wrong ones.
thanks
thanks
- TerryK
24 Sep 2010 18:21 - 24 Sep 2010 18:24 #401514
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic what other bikes can i get carbs from
Early GSXR 750 34mm Mikuni flat slides work great (I love mine) You'll need the larger carb flanges and some custom cables but I can give you some good jetting guidelines if you find some of these carbs.
Most early Suzuki GS carbs are bolt ons as well, just check spacing.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 24 Sep 2010 18:24 by TerryK.
- Polar_Bus
- Thank you received: 7
28 Sep 2010 03:32 #402392
by Polar_Bus
Bikes:
'84 GPz1100
'06 HD Fatboy
Replied by Polar_Bus on topic what other bikes can i get carbs from
fochtup1 wrote:
GS1100 carbs will bolt on as well.
justin
Bikes:
'84 GPz1100
'06 HD Fatboy
