Fuel Valve Position?
  • P21
  • P21's Avatar Topic Author
23 Sep 2010 19:46
#401322
New to the forum here and i just pick up a 2002 KZ1000 P21
how this valve work RES ON Prime
Ok prime is long handle down
Res is to the left of petcock
On is to the right of petcock
which way is the long handle to be?
Thanks for the help
Ride Safe
Kawasaki KZ 1000 Police (2002) P21
  • Motor Head
  • Motor Head's Avatar
Re: Fuel Valve Position?
23 Sep 2010 19:52
#401325
"Prime" is for filling the carb bowls after its sat a while. "On" is normal riding and for when its parked, still fine. "RES" is for approximately a 1 gallon reserve, when the normal "ON" runs low. Also OK to leave parked in this position, as the petcock is shut on and off by engine Vacuum. Just don't park for long periods, maybe even overnight with it turned to "Prime".
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
23 Sep 2010 20:48
#401338
I'm not sure about the P model petcock,but is there not an arrow indicator molded into the lever?
1977 KZ1000 A-1
24 Sep 2010 01:38 - 25 Sep 2010 02:55
#401359
Thanks for the help
Ride Safe
Hello, Bob, and WELCOME to KZR! :cheer:
In the example pictured below, the petcock is in ON position with handle pointed at 6 o'clock.
Rotating handle counterclockwise 90 degrees to point at 3 o'clock would be PRI position.
Rotating handle counterclockwise 180 degrees to point at 12 o'clock would be RES position.
In other words, the petcock handle covers the selected position lettering.
Good Fortune! :)
Last edit: 25 Sep 2010 02:55 by Patton.
  • P21
24 Sep 2010 19:59
#401541
Thank You
just what i was looking for great info Thanks Again
