Air Pump Hose to Air Box
- psrumors
23 Sep 2010 08:42 #401149
by psrumors
'82 KZ1000-K2 LTD
Air Pump Hose to Air Box was created by psrumors
What is used to connect the air pump hose to the top of the air box?
I am removing the pods on the bike I just bought and the box only has a rubber grommet.
Should this be a PVC or just a barbed fitting?
The Kawasaki service manual doesn't show much.
'82 KZ1000-K2 LTD
- kz110082
23 Sep 2010 10:47 #401177
by kz110082
1982 KZ1100A. no modifications yet
Replied by kz110082 on topic Air Pump Hose to Air Box
its literally just a hose with an OD same as the ID of the grommet. its just run through the grommet about 3/4 to inch and it stays in. There arent any special fittings. I just deleted my smog pump. so if you need that hose i got it for ya.
- psrumors
23 Sep 2010 11:12 #401190
by psrumors
'82 KZ1000-K2 LTD
Replied by psrumors on topic Air Pump Hose to Air Box
Thanks for the info. I have the hose just wasn't sure if there was any type of barbed connection.
Are there any adverse effects from removing the pump?
Did you just put a filter on the valve cover?
'82 KZ1000-K2 LTD
- MFolks
- Thank you received: 540
23 Sep 2010 11:15 #401192
by MFolks
Replied by MFolks on topic Air Pump Hose to Air Box
Why not just remove the "Smog" system and use one of these block off plates.I like the TPO kit as it's got vinyl sealimg caps for where the hoses went.
Smog Block Off Plates
www.tpoparts.com
www.kzzone.com/billet.html
www.tpoparts.com
- loudhvx
- Thank you received: 1616
25 Sep 2010 11:11 - 25 Sep 2010 11:14 #401662
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Air Pump Hose to Air Box
psrumors wrote:
You must block off the ports on the valve cover with plates like Mfolks mentioned (like his second link, but make sure they fit, not all bikes use the same size plates). Or you can just connect the two ports together with a hose.
It's not really an air pump, but performs the same function... it allows fresh air in the exhaust to continue burning after the gases leave the motor. It's just a valve. The vacuum from the intake controls whether the valve is open or not. Usually when it starts to malfunction, you get backfiring in the exhaust when decelerating.
Also, don't forget to cap off where the vacuum lines went to the intake ports as well.
1981 KZ550 D1 gpz.
Other links.
Last edit: 25 Sep 2010 11:14 by loudhvx.
