need help
- stay0820
22 Sep 2010 19:47 #401052
by stay0820
need help was created by stay0820
I have a 83 kz550 and i cant figure out were to connect the vacuum line off of the petcock. Please help
- Motor Head
- Thank you received: 391
22 Sep 2010 20:26 #401062
by Motor Head
Replied by Motor Head on topic need help
The vacuum line from the petcock would go to the #2 carb manifold nipple. Look at the black rubber manifold between the cylinder head and carb, there should be a nipple either on the top or the bottom. Each manifold should have one, #1 and #4 should have hoses going together to a "T", then forward to your air control valve. This along with the fresh air system might have been removed and plugged though. #3 should just be capped.
- stay0820
26 Sep 2010 19:22 #402104
by stay0820
Replied by stay0820 on topic need help
thanks my bike is running like a champ.
