Price check !
- coach59
Quote coming from a local shop....seems high to me, but I don't have anything to compare it to...( I've not yet received other quotes from local shops..)
How often should this service be performed? Yikes ! :ohmy:
Thanks
- PLUMMEN
- Thank you received: 104
- Motor Head
- Thank you received: 391
The carbs would also hopefully be with 4 new carb kits, with the removal disassembly- reassembly syncing etc. Kits alone would be $100 for 4, or more.
- larrycavan
- Visitor
Does $400 seem reasonable to clean the carbs (ultra-sonic ) and $180 for a valve adjustment ? ('82 KZ750 LTD)
Thanks
Valve adjustment is a 1.5 hour job plus the gasket & maybe cam end plugs.
After carbs are cleaned and the valves adjusted, the carbs need to be synchronized. Is that included or extra cost?
Should have new spark plugs and possibly air filter & oil/filter change to complete the tune up.
- austin3119
- Thank you received: 7
- sparkn
1979 KZ650 SR
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- loudhvx
- Thank you received: 1616
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
