unplugged nipples on carb boots
17 Sep 2010 18:18 #399433 by Lazyman06
unplugged nipples on carb boots was created by Lazyman06
I've got two nipples without vacuum plugs on the. Are they supposed to have hoses coming off of them or do I just put some plugs on it and forget about it
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
17 Sep 2010 18:22 #399435 by MFolks
Replied by MFolks on topic unplugged nipples on carb boots
Does your bike have the Kawasaki supplied smog gear(reed valves in the head,vacuum lines and an air switch in front of the coils under the tank?
Normally, the nipples for carb sync have no other lines going to them. If yours are missing, Z1 can get replacements for you as the engine will run lean without them.
17 Sep 2010 18:32 #399439 by Lazyman06
Replied by Lazyman06 on topic unplugged nipples on carb boots
well when tri gave me his old boots they were missing already. That being said my old ones had the plugs still on them so I can use them if need be.
17 Sep 2010 20:20 #399491 by Patton
Replied by Patton on topic unplugged nipples on carb boots
Be sure not plugging the float bowl vent nipples.
Photo courtesy of wgcarbs.com :cheer:
Good Fortune! :)
17 Sep 2010 20:30 #399496 by Lazyman06
I'll try to watch out for that ;)
  • trianglelaguna
18 Sep 2010 02:17 #399539 by trianglelaguna
Replied by trianglelaguna on topic unplugged nipples on carb boots
they had smoig lines running to em and i did not check to see if had more nipples to plug em..that said i should check the boots on my MKII when i go to set timing and see if i can start riding it this weekend...plug em...unless you have the rubber snorlkes coming of you exhaust side cam covers.(up through under the tank by the coils).then if you do you may wanna look for two small black rubber lines coming off all that plumbing that would reach down to those two intake boots,as that was the orig routing location imo
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
