cleaning my carbs
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
Re: cleaning my carbs
15 Sep 2010 10:32
#398880
1978 KZ1000A2
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
16 Sep 2010 20:27 - 16 Sep 2010 20:28
#399234
See, its not that difficult :laugh: When you use the diagrams I supplied and the manual. ;)
I always seperate carbs due to the fact that many have had clogs and varnish in the fuel transfer lines between carbs.
Did you spray carb cleaner through all the carb passage ways?.. and watch it squirt through the small holes in the bores???
If not, then be prepared to take them apart again when guessing later why things arent quite right...
Good luck!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 16 Sep 2010 20:28 by TeK9iNe.
  • Motor Head
  • Motor Head's Avatar
23 Sep 2010 14:50
#401227
So when you did all of this, you did not have or use carb kits? :unsure:
  • kz1k
23 Sep 2010 14:55
#401230
correct....reason being was, when i took the bowls off the floats were stuck. i couldnt even move the butterfly. i took em apart, cleaned em enough to see if it would work mechanically. once i figured it was ok, i knew the carbs were ok and i didnt need to buy any. itll be a while before i use the carbs with all thats going on, so the way i see it...practice makes perfect.
btw, i didnt spray cleaner through holes to see if it would come out certain passages. i read about it after i did the carbs, so taking them apart again and giving them a thourough cleaning, (better than the first) i can add my gaskets and slap her in.
good q though....i do shit ass backwards sometimes...dont ask why because i couldnt tell ya....the doc says im crazy, whatever that means.
1978 KZ1000A2
