cleaning my carbs
- kz1k
- You Cant Fix Stupid!
Re: cleaning my carbs
15 Sep 2010 08:42
1978 KZ1000A2
- kz1k
15 Sep 2010 08:43
also, the rod that goes through the 4 carbs....where does it fasten?
1978 KZ1000A2
- Kidkawie
- I bleed premix
15 Sep 2010 08:46
See, all those puzzling questions is why I left mine together. Good luck man. As far as the floats, just search "clear tube" and you'll see how to do it. On my float bowls I don't have a provision for a tube so I used the pen tip method and a short piece of fuel line(also found on these forums).
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- kz1k
15 Sep 2010 09:11 - 15 Sep 2010 09:12
thanks ill check that out, but for now i need to get all the parts in. i would have left them strapped together, but was told to take them apart...
1978 KZ1000A2
Last edit: 15 Sep 2010 09:12 by kz1k.
- kz1k
15 Sep 2010 09:13
1978 KZ1000A2
- kz1k
15 Sep 2010 09:15
1978 KZ1000A2
- Kidkawie
- I bleed premix
15 Sep 2010 09:15 - 15 Sep 2010 09:16
kz1k wrote:
If you look back at your first coupla posts there's a pic with this piece installed....might help.
1975 Z1 900
2004 KX125
2004 KX125
Last edit: 15 Sep 2010 09:16 by Kidkawie.
- kz1k
15 Sep 2010 09:17
1978 KZ1000A2
- Motor Head
15 Sep 2010 09:23
Look at those pictures you posted, see how the throttle slide valves are up in their bore near the top? Also at very different heights? You need to take the tops off all 4 cabs, these are held on by three screws each, the covers/ lids whatever. You will see that the "Connecting" rod that goes through for all 4 carbs is not in place. This must be installed, and the other "Bell Crank" with the throttle cable fitting will go on with this rod, at carb #3, which is the 3rd carb from the left, looking at them just like you photo's.
WHERE IS YOUR BOOK?????
Go to Kawasaki.com or another bike web site, look at the parts diagrams they will have a breakdown of the carbs, it was also posted somewhere in one of you threads before.
You must have this throttle linkage in place, and then you must adjust each one of the 4 throttle valve slides so they are even, ie "Bench Sync". When they are nearly closed use a small piece of round wire for a "Feeler Gauge", some use a paper clip. Adjust all 4 of those throttle valves/ slides so they are even at the Idle position.
You need a Book!!
You need a Book!!
- kz1k
15 Sep 2010 09:43
false alarm...shes back together and the butterfly works great. thanks kz.
1978 KZ1000A2
- Kidkawie
- I bleed premix
15 Sep 2010 09:46
Hey, check out these pics:
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...0655549970&viewitem=
1975 Z1 900
2004 KX125
2004 KX125
- kz1k
15 Sep 2010 10:32
1978 KZ1000A2
