gas leak
- coach59
Why would adding gas cause this now - with no indication of anything being different the last couple of weeks?
The only that has changed (at least that I can tell ) is the tank has more gas in it.
- Motor Head
- Thank you received: 391
- coach59
- Motor Head
- Motor Head
I guess it could be coming from the Tank, either a seam failing or a rust hole. Usually the rust holes would be right along the bottom. You could take the tank off and see if the leak follows it.
Oh that's right you had a bit of info on you tank, pretty rusty. What did you do to correct it?
- coach59
- Motor Head
- larrycavan
- Visitor
Well if it is oil, which you stated a Brown fluid, then it would have a different viscosity to it, and a taste. Its kinda necessary sometimes to take a small taste to confirm the liquid. Oil mixed with gas will still taste and smell different than one or the other by itself.
:laugh: What does ATF with a dash of fork oil taste like?
- larrycavan
- Visitor
- gd4now
- Denco where did you go?
- Thank you received: 445
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
