popping noise
- coach59
popping noise
10 Sep 2010 20:05 - 10 Sep 2010 20:06
I've noticed (in lower gears) some decel "popping"...is this related to fuel mixture? Or something else altogether? Where's the easiest place to identify and correct something like this? Also, I'm using 87+ octane - Am I safe with this type? I have an '82 KZ750 LTD.
Thanks for the help....
Last edit: 10 Sep 2010 20:06 by coach59.
- Nebr_Rex
Re: popping noise
10 Sep 2010 20:11
idle curcuit is a little lean
adjust mixture screws or install bigger pilot jets
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- loudhvx
Re: popping noise
10 Sep 2010 20:34
The air injection system will cause that popping when the diaphragm valve ges defective. Try capping the ports on the op of the valve cover, and capping the vac lines going to the air switch above the motor.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- bountyhunter
Re: popping noise
10 Sep 2010 21:19
It's likely the pilot jet is too lean but it can also be a vacuum leak.
- TeK9iNe
- What did you do!?!
Re: popping noise
10 Sep 2010 21:47
Good advise so far...
If the engine is in a known good running condition state, and everything is stock - air box/stock filter, stock exhaust, then the stock # turns out on the mixture screws, and the stock jets will work fine in a clean set of carbs.
Dont start to change out jets. Additional air is getting into one, or more of the cylinders. Making sure that absolutely everything is air tight from the air filter to the exhaust tip is crucial to proper operation.
The carb to engine holders is the usual culprit, and a good cleaning and some Permatex motoseal, or #2 gasket maker will take care of that.
With the bike running, spray wd40 on the carb linkage and seals, etc. listen for rom change, and watch exhaust for black puff if any gets sucked in a leak.
Make sure the airbox conections/hoses are all air tight at the carbs. If they're dried up and hard, replace them.
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- bountyhunter
Re: popping noise
11 Sep 2010 13:48
Another thing that will make it pop is a leak at the exhaust header gasket where it goes on the engine.
- bikerjim
- 1986 T-type Regal
Re: popping noise
11 Sep 2010 14:55
I tightened my right side header clamp, and the slight popping, which I had on the right side while decelerating, went away. Don't tighten too much, though. Keep within torque spec.
1959 Sears moped, 49cc
50's/60's Peugeot moped, 49cc
50's Mustang motorcycle
1959 Royal Enfield Indian Chief, 700cc
1979 KZ750B, owned since new
- KYKZ1100
Re: popping noise
11 Sep 2010 23:47 - 11 Sep 2010 23:52
I've had popping for three years in my KZ1100 - ever since I put it together. I've tried everything - new valves, pistons, rings, carb holders, vacuum caps, exhaust gaskets, larger pilot jets (twice), sealing off air recirculation system, adjusting float levels, adjusting fuel mixture screws, etc. Today I sync'd the carbs and used a ColorTune to see what was going on in the cylinders. After the sync there was still popping but even though it idled well there was no combustion in one of the cylinders - the plug was firing but no fuel was being burned. I adjusted the air (fuel?) mixture screw until that cylinder was firing at idle and the popping is gone. I'm pretty happy - the popping was really bugging me and it's gone. Did I mention that the popping is gone?
1981 KZ1100A1 Shaft
2007 BMW R1200R
2007 BMW R1200R
Last edit: 11 Sep 2010 23:52 by KYKZ1100.
- loudhvx
Re: popping noise
12 Sep 2010 00:10
KYKZ1100 wrote:
But what happened to the popping?
1981 KZ550 D1 gpz.
Other links.
Other links.
Re: popping noise
12 Sep 2010 06:19
KYKZ1100 wrote:
If you later miss the popping sound you may want to put a tablespoon of unpopped popcorn in each muffer for old times sake. :silly:
- Old Man Rock
Re: popping noise
12 Sep 2010 06:43
Maybe I missed it but you didn't mention if the popping was gone?..... :laugh: :laugh: :laugh:
"Color-Tune to see what was going on in the cylinders. "...
Thank you, for an outsider (other than me) just proved once again why this is a handy tool to have around... You can see what's going on in the chamber....
How much more easier can that be in adjustments and T-shooting....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- TeK9iNe
Re: popping noise
12 Sep 2010 19:57
Old Man Rock wrote:
+1 Agreed... Love that tool now, it saves me sooo much time.
Before, I would have to hold the rpm up slightly where an engine popped worst and crank more mixture into the cylinders via the mix screws to determine which cylinder/carb had an issue. Now I jsut throw in the colortune, and I can see immediately where I need to be/what to do, without an hours extra work.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
