FUEL LEAK
- hardknocks
09 Sep 2010 22:44 - 09 Sep 2010 23:36 #397394
by hardknocks
FUEL LEAK was created by hardknocks
HELLO EVERYONE...BEEN A LONG TIME SINCE I HAVE BEEN ON i HAD TO SET UP A NEW PAGE...LOL ANY HOW.. I HAVE A FUEL LEAK ON THE 3RD CARB COUNTING LEFT TO RIGHT SITTING ON BIKE... WHERE THE CHOKE OR FAST IDLE CAM GOES INTO THE CARB.AND IT IS A FAST LEAK... HAS ANYONE HAD THIS ISSUE AND CAN SOMEONE GIVE ME SOME HELP...THANKS I had the carbs rebuilt last year... has been running great..
KEIHIN CV 34 CARBS
1981 KZ 750
KEIHIN CV 34 CARBS
1981 KZ 750
Last edit: 09 Sep 2010 23:36 by hardknocks.
- Thank you received: 2098
10 Sep 2010 07:48 #397429
by Patton
Replied by Patton on topic FUEL LEAK
Maybe some help --
Click here > www.wgcarbs.com//index.php?option=com_co...view&id=25&Itemid=25
10 Sep 2010 07:53 #397432
by Patton
Wild guess --- is petcock allowing fuel to drain toward carb vacuum nipple through the vacuum tube from carb to petcock (perhaps due to petcock diaphragm damage)?
- gangstajay
10 Sep 2010 10:20 #397468
by gangstajay
Replied by gangstajay on topic FUEL LEAK
ok so my dumb self... i pulled the carbs off put on a bench and connected fuel line and it was leaking out were the line went into the carb..tighted up the line seemed to have stopped...will let it sit for a few days then recheck thats when it leaks after it sit's for a week or so...keep u posted
10 Sep 2010 16:46 - 10 Sep 2010 16:56 #397524
by Patton
There's a carb fuel intake tee fitting between the middle two carbs.
Maybe all the fuel leakage was from just a loose fuel line where it attaches to the tee.
With the "correct" size fuel hose i.d., it's often unnecessary to use any type of clamp when attaching the fuel hose to whatever fitting.
I use the best non-kinking type fuel hose available, with smooth curves, usually without any clamps, and suffer no leakage whatever.
If leakage persists after tightening the attachment of fuel line to the tee, would then suspect damaged or deteriorated o-rings on the tee where the tee fits into the carbs.
Last edit: 10 Sep 2010 16:56 by Patton.
