Removing PODs / Question
08 Sep 2010 16:25 #397076 by psrumors
Removing PODs / Question was created by psrumors
Picked up a '82 1000 LTD last weekend that has PODs. The bike runs pretty darn good until full throttle at which time there is a stumble.
I don't want to fool with getting the carbs right and have a factory air box on the way.
I know the carbs were jetted for the PODs per the previous owner but beyond that he had no idea what had been done, slides drilled or anything else.
What are the chances of just being able to throw the air box back on?
Do you think I will need to pull the carbs apart?
'82 KZ1000-K2 LTD
08 Sep 2010 16:30 #397077 by Nebr_Rex
Replied by Nebr_Rex on topic Removing PODs / Question
It is better to know what you dealing with now,than have to take it all apart to mess with it later.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • muddy1
  • 1980 Kz1000 LTD B4
08 Sep 2010 16:43 #397081 by muddy1
Replied by muddy1 on topic Removing PODs / Question
Put the stock airbox back on and feel the rush of power, those carbs need the stock box in order to work/function correctly..
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
  • Motor Head
08 Sep 2010 18:06 #397106 by Motor Head
Replied by Motor Head on topic Removing PODs / Question
In order to fit the stock air box back in, you will have the carbs off anyway. I would put the jetting back to Stock for your bike, unless you have a 4-1 header. Then maybe a size or 2 up on the mains. Just be sure of when you check the stamped # on the jets that are there now that they have not been drilled or reamed. Best to get kits with new jets. Go right through them, and do it good.
16 Sep 2010 07:26 #399082 by seanof30306
Replied by seanof30306 on topic Removing PODs / Question
OK, I'm a little curious about this. Three years ago, when I joined this site, the prevailing thinking was pods were a good thing, albeit with some problems. Now, it appears that has changed, and most people now reccomend the stock airbox.
It's the same thing I noticed with the WG coil repowering mod and the Dyna S ignition. Three years ago, everyone said do the mod, and get the Dyna S, now, people scoff and make jokes about them.
I'm not trying to stir anything up, and I have no opinion either way. I come here because I don't know much and want advice from people more knowledgable, but it's frustrating when you take the advice that is given and approved of by the the great majority, only to be told later you went the wrong way.
Why has there been such a shift in thinking on these things?
Also, My '79 KZ650 has pods and a MAC 4/1. When I was rebuilding the carbs, I was told to go from 15/92 to 17/110. The bike smoked (black) constantly, fouled plugs religiously, and started on days as cold as 14 degrees without the need of the choke. I went back to the 15/92s, thinking I'd have to go bigger on the main jets, but with the exception of being really cold natured when first started, the bike runs great.
It doesn't make any sense to me, I'd think it'd be way lean with those pods, that pipe, and those jets, but that is not the case.
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
