78 kz 650 RUNNING ON TWO ARRGGG
- coldkz
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- coldkz
- Nebr_Rex
- Thank you received: 300
Hi fellas finnaly got the bike to fire its running on 1 and 2 only pulled the bottom off the carbs cleaned everything that was brass blew everything out the slides are free and smooth...as it idles i can take a can of starter fluid and give 3 an 4 a little shot and it revs up...arrg this thing sat for 25 years changed out the harness it was burnt and im getting so close any ideas???thannks in advance....
Do you have a repair manual? If not get one.
Completely go thru the carbs.They're going to be cruded up from sitting so long.
1 & 4 fire at the same time of off the same coil and 3 & 4 do the same.So if 1 & 2 are firing and 3 & 4 are not it shouldn't be the ignition (check the plugs though) .
Also check carb boots.
They are the rubber parts between the carbs and the Cylinder head.Spray a little sarter fluid around them and any change would suggest they leak and need replacement.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- Nebr_Rex
i will check the points next 1 and 2 pipes get hot 3 and 4 no the coils are split 1 and 3 2 and 4 so im firing on 1 and 2 utillizing both coils hmmmm also weird because when i give it a shot of either in 3 and 4 it revs up oddddd? thanks again
1 & 4,2 & 3
check plug wires
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- bikerjim
- 1986 T-type Regal
If 3&4 kick in when you fully open the throttle, then you probably have something wrong with the pilot system, which controls fuel flow at idle/low throttle position. This may require disassembly again and a more thorough cleaning of those passages with spray cleaner and some compressed air (maybe even some wire to clean out the passages.....be careful with that, as you could damage the passages if you are too aggresive with the wire. A carb cleaning tool with several sized wires is available, but I can't remember where I saw it.
You probably have already done obvious things such as compression check to eliminate problems in the cylinders to make sure they are able to fire.
Suggest you get a factory service manual somewhere if possible. Mine has a pictorial of the passageways in the carbs, so you will be able to understand how the passages were drilled and connect together.
Maybe some other more informed folks will be able to suggest other possibilities.
Good luck.
1959 Sears moped, 49cc
50's/60's Peugeot moped, 49cc
50's Mustang motorcycle
1959 Royal Enfield Indian Chief, 700cc
1979 KZ750B, owned since new
- Thank you received: 2829
- bikerjim
- 1986 T-type Regal
- OnkelB
- Thank you received: 80
the coils are split 1 and 3, 2 and 4 so im firing on 1 and 2 utilizing both coils
As already mentioned by Nebr_Rex one coil should fire cyl. 1 and 4, the other should fire cyl. 2 and 3, so if your coils are split like you describe, the plug wires are connected wrong, no wonder you're running on 2 cylinders - you likely have spark on all 4 cylinders, only two of them are firing when not on the compression stroke.
Remove the points cover and look at the timing plate, one set of points will have a green wire attached to it, the other set will have a black wire. The left/rear set of points fires cyl. 1 and 4 (whether it has a green or black wire, don't rely on color codes, you never know what some po did), the right/front set of points fires cyl. 2 and 3
To recap, check that the coil connected to the left set of points has the plug wires connected to cyl. 1 and 4 and the coil connected to the right set of points has the plug wires connected to cyl. 2 and 3.
Edit: After rereading your post, first try switching the plug caps on cyl. 3 and 4 (3 to 4, 4 to 3), if I understood you right that should do the trick.
77 KZ 650 B1, 82 GPz 1100 B2.
- Thank you received: 2098
- coldkz
- rstnick
- Thank you received: 377
Hope you figure this out soon.
Check it out again, and report back.
Where are you in Canada?
I'm in Ontario.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
