78 kz 650 RUNNING ON TWO ARRGGG
07 Sep 2010 10:11 #396758 by coldkz
78 kz 650 RUNNING ON TWO ARRGGG was created by coldkz
Hi fellas finnaly got the bike to fire its running on 1 and 2 only pulled the bottom off the carbs cleaned everything that was brass blew everything out the slides are free and smooth...as it idles i can take a can of starter fluid and give 3 an 4 a little shot and it revs up...arrg this thing sat for 25 years changed out the harness it was burnt and im getting so close any ideas???thannks in advance....
  • trianglelaguna
07 Sep 2010 10:19 #396761 by trianglelaguna
Replied by trianglelaguna on topic 78 kz 650 RUNNING ON TWO ARRGGG
hey when it revs does any heat in the other exhaust pipes appear...i bet you either have a set of points not working or a coil not hooked up right ect.ect
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
07 Sep 2010 10:27 #396767 by coldkz
Replied by coldkz on topic 78 kz 650 RUNNING ON TWO ARRGGG
i will check the points next 1 and 2 pipes get hot 3 and 4 no the coils are split 1 and 3 2 and 4 so im firing on 1 and 2 utillizing both coils hmmmm also weird because when i give it a shot of either in 3 and 4 it revs up oddddd? thanks again
07 Sep 2010 10:28 #396768 by Nebr_Rex
Replied by Nebr_Rex on topic 78 kz 650 RUNNING ON TWO ARRGGG
Do you have a repair manual? If not get one.
Completely go thru the carbs.They're going to be cruded up from sitting so long.
1 & 4 fire at the same time of off the same coil and 3 & 4 do the same.So if 1 & 2 are firing and 3 & 4 are not it shouldn't be the ignition (check the plugs though) .
Also check carb boots.
They are the rubber parts between the carbs and the Cylinder head.Spray a little sarter fluid around them and any change would suggest they leak and need replacement.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
07 Sep 2010 10:31 #396770 by Nebr_Rex
1 & 4,2 & 3
check plug wires
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • bikerjim
  • 1986 T-type Regal
07 Sep 2010 10:35 #396773 by bikerjim
Replied by bikerjim on topic 78 kz 650 RUNNING ON TWO ARRGGG
Float needles (valves) could still be sticking due to wear, even though the carbs have been cleaned. This will prevent gas flowing into float bowl. If you can see a ring around the taper area of the needle, you should replace both needle and seat.
If 3&4 kick in when you fully open the throttle, then you probably have something wrong with the pilot system, which controls fuel flow at idle/low throttle position. This may require disassembly again and a more thorough cleaning of those passages with spray cleaner and some compressed air (maybe even some wire to clean out the passages.....be careful with that, as you could damage the passages if you are too aggresive with the wire. A carb cleaning tool with several sized wires is available, but I can't remember where I saw it.
You probably have already done obvious things such as compression check to eliminate problems in the cylinders to make sure they are able to fire.
Suggest you get a factory service manual somewhere if possible. Mine has a pictorial of the passageways in the carbs, so you will be able to understand how the passages were drilled and connect together.
Maybe some other more informed folks will be able to suggest other possibilities.
Good luck.
1959 Sears moped, 49cc
50's/60's Peugeot moped, 49cc
50's Mustang motorcycle
1959 Royal Enfield Indian Chief, 700cc
1979 KZ750B, owned since new
07 Sep 2010 10:37 #396776 by 650ed
Replied by 650ed on topic 78 kz 650 RUNNING ON TWO ARRGGG
Check to make sure carbs 3&4 are getting gas (check by pulling drain screws carefully). Since 3 & 4 both get fuel through right side of fuel T if that is clogged only 1&2 would run. Ed
  • bikerjim
  • 1986 T-type Regal
07 Sep 2010 10:58 #396781 by bikerjim
One other thing.....while you are spraying into a particular orifice, you obviously should see spray coming out the other end. The service manual with pictorial will let you know where to look to make sure the cleaner is coming out the correct location.
07 Sep 2010 13:25 - 07 Sep 2010 13:38 #396817 by OnkelB
Replied by OnkelB on topic 78 kz 650 RUNNING ON TWO ARRGGG
coldkz wrote:
the coils are split 1 and 3, 2 and 4 so im firing on 1 and 2 utilizing both coils
As already mentioned by Nebr_Rex one coil should fire cyl. 1 and 4, the other should fire cyl. 2 and 3, so if your coils are split like you describe, the plug wires are connected wrong, no wonder you're running on 2 cylinders - you likely have spark on all 4 cylinders, only two of them are firing when not on the compression stroke.
Remove the points cover and look at the timing plate, one set of points will have a green wire attached to it, the other set will have a black wire. The left/rear set of points fires cyl. 1 and 4 (whether it has a green or black wire, don't rely on color codes, you never know what some po did), the right/front set of points fires cyl. 2 and 3
To recap, check that the coil connected to the left set of points has the plug wires connected to cyl. 1 and 4 and the coil connected to the right set of points has the plug wires connected to cyl. 2 and 3.
Edit: After rereading your post, first try switching the plug caps on cyl. 3 and 4 (3 to 4, 4 to 3), if I understood you right that should do the trick.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 07 Sep 2010 13:38 by OnkelB.
07 Sep 2010 17:10 #396864 by Patton
Replied by Patton on topic 78 kz 650 RUNNING ON TWO ARRGGG
Good Fortune! :)
07 Sep 2010 19:05 #396899 by coldkz
yes sorry guys 1 and 4 2 and 3 im a big dummy im going out in the morning to attack it again thanks so much for the help...if your in canada and need something painted drop me a line my paint is way better than my wiring skills but always fun to learn
08 Sep 2010 18:24 #397113 by rstnick
Replied by rstnick on topic 78 kz 650 RUNNING ON TWO ARRGGG
Welcome coldkz.
Hope you figure this out soon.
Check it out again, and report back. ;)
Where are you in Canada?
I'm in Ontario.
B)
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
