- Thank you received: 1
New Airbox Ducts
- nicksorg
Thanks
Nick
1982 Kawasaki KZ1000-K2
- 9am53
- homebrew, and some bbq
- Thank you received: 3
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- Nebr_Rex
- Thank you received: 300
the new ones are very soft, really easy to work with.
+1
Just installed them on my KZ750e with BS34s.
$45 + shipping @ Z1 Ent.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- nicksorg
Nick
- Nebr_Rex
Thanks for the info. Just curious if you replaced an existing set and if they made any noticable difference in the way your bike is running.
Nick
Bought the bike with factory Keihins.
Switched to BS34s,changed exhaust and installed the new ducts at the same time.
Ran ok when I first got the bike,now it runs great.
Ducts where rock hard.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- PLUMMEN
- Thank you received: 104
- hocbj23
- Visitor
- nicksorg
Nick
- Thank you received: 2098
I bit the bullet and ordered a set from Z1. Hopefully it helps or completely fixes my high idle problem. I won't know for awhile as I'm waiting for parts to fix my starter clutch.
Nick
Nice soft pliable air box hoses will help make removal and replacement of carbs almost enjoyable, especially when compared to contending with the typical rock hard examples.
For "high idle problem," would more suspect post-carb air leak as opposed to pre-carb air leak.
May also need new carb holders. And perhaps also new vacuum plugs.
Would test for air leaks by spraying brake cleaner, WD40, propane, etc., about carb holder and any other possible air leak sites, while engine is idling.
Air leak would be indicated by change in idle rpm and probably also smoke from exhausts.
- nicksorg
I'm still waiting for parts to come in so I can fix my starter clutch, but I have to believe these will make a big difference, if for nothing else, the ease of putting them on. Thanks to all those for suggesting I replace them.
Nick
- nicksorg
Thanks.
Nick
