- Thank you received: 1
Pilot Jet Plug Question
- nicksorg
07 Sep 2010 05:02 - 07 Sep 2010 05:05 #396684
by nicksorg
1982 Kawasaki KZ1000-K2
Pilot Jet Plug Question was created by nicksorg
What would you guys suggest for a sealer to put on around the plugs that cover the pilot jet towers in the float bowls of my Mikuni BS34s on GPz750. The plugs came with the rebuild kit.
Thanks
Nick
Thanks
Nick
Last edit: 07 Sep 2010 05:05 by nicksorg.
- JR
- Thank you received: 449
07 Sep 2010 06:03 #396695
by JR
Replied by JR on topic Pilot Jet Plug Question
Did you get O rings in the rebuild kit ?
A good fitting O ring on the plug should be enough.
- nicksorg
07 Sep 2010 07:29 #396710
by nicksorg
Replied by nicksorg on topic Pilot Jet Plug Question
I did get O rings in the kit, but I don't think they were the correct size. I picked up some but was wondering if they were sealing enough. Maybe I'm paranoid.
Thanks
Thanks
- JR
07 Sep 2010 10:29 #396769
by JR
With the correct O ring that plug should be a snug fit which is all you need.
If you go to www.kawasaki.com , Owner info, Parts Diagrams etc etc you should see an O ring
- TeK9iNe
- What did you do!?!
- Thank you received: 28
07 Sep 2010 10:39 #396777
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Pilot Jet Plug Question
As said, the correct o-ring is fine, and it just slides in with a little grease/oil or gas as lubricant. It just sits there, and usually can be removed with a firm tug via fingernails or small needle-nose pliers for easier removal.
Good Luck.
Good Luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- otakar
07 Sep 2010 13:10 #396815
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Pilot Jet Plug Question
I agree with the previous posts. I would not use a sealer of any kind. "O" rings are good enough. If the ones you have are not the correct size than any Neoprene or Viton seals that fit are fine.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
