where does it go?
- sdw25
where does it go?
15 Apr 2006 05:50
Does anybody know where the vacuum line hooks to from the petcock.I have read in the forum under hose placement and it says to carb #2 does that mean to the intake where you would hook a syncronizer to? My carbs has three angled nipples one on #1,#2 and#3 carb? please help thank you
[img size=352]
Post edited by: sdw25, at: 2006/04/15 08:51
dale
crandall,ga
78 kz650 sr emgo pods 4 into 1 exhaust
crandall,ga
- rammy
Re: where does it go?
15 Apr 2006 06:34
sdw25 wrote:
The vacuum line from the tank goes to #2 intake boot and make sure the rest intake boots have the plugs on them.
as for the the vent holes on the carbs them selfs should be open unless there is vacuum then i would plug them. I had a set of carbs some one had hodge podded together and I had vacuum in 1 of those vent holes and put a cap on it and everything worked good till I was able to get a `good ` set of carbs that were not hodge podded.
Does anybody know where the vacuum line hooks to from the petcock.I have read in the forum under hose placement and it says to carb #2 does that mean to the intake where you would hook a syncronizer to? My carbs has three angled nipples one on #1,#2 and#3 carb? please help thank you [img size=352]
Post edited by: sdw25, at: 2006/04/15 08:51<br><br>Post edited by: sdw25, at: 2006/04/15 08:51
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
- sdw25
15 Apr 2006 12:08
thanks for the help
dale
crandall,ga
crandall,ga
- rstnick
15 Apr 2006 15:21
The vacuum line does NOT go to the #2 Intake boot. All Intake boot should have caps on them. These are used for synchronizing (sp?) the carbs.
The picture at the bottom on this page: Carb Connections shows the connection on the # 2 carb, just in front of the vent connection.
The two vents should have hoses that go up and over the air box and then just hang down, not connected to anything.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
