carbs flooding
- bic3851
05 Sep 2010 13:27 #396301
by bic3851
carbs flooding was created by bic3851
My Z750 floods in to the air box. I got a different set of carbs and they do the same fuel pissy out of the back of the carbs all 4...?? into the air box
- mark1122
- Keep twisting it
- Thank you received: 109
05 Sep 2010 13:42 #396303
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic carbs flooding
this would normally be caused by poorly seating float needles. Remove them and inspect for issues. check that the screen above them doesn’t have rust in them. if they do, check the tank.
also verify that the float level is correct, do a bench measurement, then after they stop leaking , by using the clear tube test.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
