Bike wont run right with choke off
  • nobull84
  • nobull84's Avatar Topic Author
30 Aug 2010 14:57
#395068
I have a 82 kz440. just had the carb worked on and it ran good for two days. but now it wont run right and it wants to backfire alittle and the carb knocks. any help would be great, thanks.
  • Motor Head
  • Motor Head's Avatar
Re: Bike wont run right with choke off
30 Aug 2010 17:34
#395099
Did you pay someone or shop to do the work? Then it should go back, for a redo. Did they clean the Tank, and install a in line fuel filter?
Sounds like a plugged pilot circuit, or possibly a vacuum leak. You could check the hoses hooked to the car manifolds, and the manifolds for vacuum leaks.
Oh welcome to KZR, lots of good info here.
  • timebomb33
  • timebomb33's Avatar
30 Aug 2010 18:35
#395115
ditto times 2
I THINK MY POWERBAND BROKE
  • nobull84
31 Aug 2010 11:17
#395227
Thank u I called the shop they r dumb@$$es. I rebuilt it myself and its great now.B)
  • Motor Head
31 Aug 2010 14:46
#395251
Good, did you install a good in line filter, and clean the tank?
  • nobull84
02 Sep 2010 11:02
#395624
Yes
