- Thank you received: 1616
air screws and pilot jet size
- stonemaster
- Visitor
also I'm running 20 on pilot jets and have been fighting a lean problem which i solve by turning air screws in to slightly less than one turn out., would changing to 17.5 pilot jet (which I happen to have ) help this ??
- loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Polar_Bus
- Thank you received: 7
adjusting air screws, on three of em I turn all the way in and it drowns the bike out like its supposed to, but the other no change, clogged pilot jet maybe????
I'm confused. You say you're fighting a "lean" problem ? Explain in further details. Secondly what type of carbs do you have ? With Mikuni CV type carbs, turning the air screw CW leans out the idle mixture, if you have Mikuni VM type carbs, turning the air screws CW richens the mixture.
Bikes:
'84 GPz1100
'06 HD Fatboy
- stonemaster
- Visitor
- stonemaster
- Visitor
Sometimes this can be caused by the carbs being unbalanced (out of sync). Since one carb will have it's slide lower, that one may have a far more sensitive air/mixture screw.
uh the air screw on my #4 carb can be turned in either direction and no apparent change, when i turn the air screws all the way in on the other 3 carbs (one at a time of course) it bogs the motor down as it should. This is at idle of course.
