Poor Idle Issues
- WMKZ900
It starts easy and run through the RPM range flawlessly.
However, it has not idled well for several years. When riding, pulling up to a light requires that the rpm does not drop below 1500.
I have cleaned an been through the carbs recently without any improvement.
It ildes poorly and hunts up an down, if set below 1500 rpm then stops.
Yesterday, I warmed it up to operating temp, turn off the engine ,cooled the pipes with a fan. Restarted and felt the pipipes at a 1500 rpm idle. The tempertures varied from pipe to pipe. I turned the air screws out on the hotter pipes and saw a slight improvement.
Suggestion would be greatly appreciated.
Have and Running
66 Honda S90
71 Honda CB350
71 Kawasaki H1 500
73 Kawasaki H2 750
76 Kawasaki KZ900
06 Kawasaki Concours
Had
65 Honda S65
68 Honda CL 175
71 Honda CB 450
72 Kawasaki H2 750
74 Kawasaki H2 750
- Thank you received: 2829
- Motor Head
- Thank you received: 391
- WMKZ900
Have and Running
66 Honda S90
71 Honda CB350
71 Kawasaki H1 500
73 Kawasaki H2 750
76 Kawasaki KZ900
Had
65 Honda S65
68 Honda CL 175
71 Honda CB 450
72 Kawasaki H2 750
74 Kawasaki H2 750
- WMKZ900
I'll go back and check the basics. Particularly with a manometer.
Have and Running
66 Honda S90
71 Honda CB350
71 Kawasaki H1 500
73 Kawasaki H2 750
76 Kawasaki KZ900
Had
65 Honda S65
68 Honda CL 175
71 Honda CB 450
72 Kawasaki H2 750
74 Kawasaki H2 750
- Polar_Bus
- Thank you received: 7
My 76 Kz900 has the original 26 mm carbs, stock air box, and a V&H Exhaust.
A abnormally high idle or a fluctuating idle is almost always an air leak somewhere stemming from an overly lean condition.
Bikes:
'84 GPz1100
'06 HD Fatboy
I have tried spraying WD40 on the carb holders and didn't see any change. I might try that again.
When you try this be sure to idle the engine down as low as possible first. That's when it' s most likely to cause a change. Ed
- TeK9iNe
- What did you do!?!
Condition of individual cylinders.
Mixture screw setting.
Synchronization of carbs.
Ignition timing/condition.
When's the last time you did a compression test? More than a 10% + difference between cylinders will start to cause a small variance in smooth idle, that increases with further degredation of engine condition.
Don't forget to maintain your valve clearances - this is considered regular maintenence.
Sometimes, there can exist a very small air seep that can be occuring in the old carburetors themeselves, that requires very fine tuning of the idle mixtures. This has virtually no detectable effect on throttle inputs, but makes idle unstable and have a tendency to drop when coming to a stop after a quick hot run.
You will need an experienced ear/colortune plug to find the exact proper mixtures at idle.
If the pipe temperatures varied at 1500rpm (significant idle input), then your carbs are deffinately suffering from an out of sync condition, or pilot/idle mixture system clog.
Properly performed vacuum sync, and verification is absolutely necessary to achieve a low/slow idle of 900rpm or less, if desired.
Check ignition timing with a known good timing light.
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
