help identify a few items please
- bobbisman
- JMKZHI
- Thank you received: 48
I bet yours are VM24 carburetors.so i have a 1978 kz 650 and im trying to figure out what model carbs i have. from some of the research ive done it seems this model came with 24mm carbs but mine appear to be bigger. possibly 26mm. i say this because when i measure the carbs with a dial caliper it measures just over an inch. 24mm would be just under an inch. ...
I'm guessing the measurement was taken at the engine side opening.
They should be measured on either side of the throttle slide inside the carb bore.
My VM24s are ~26mm at the engine side opening & 24mm near the slides.
- Bluemeanie
- Thank you received: 14
- Injected
- Thank you received: 554
- Injected
The 24's and 26's have indentical top caps but the 28's have a flatter cap with only 2 screws instead of 3.
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- bobbisman
- Injected
As long as there are no grooves on the taper they should be fine.
