carb or ignition ?
- School Teacher
what ideas?
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
- Motor Head
- Thank you received: 391
- Thank you received: 2829
- School Teacher
yes everything stock.Are you running the stock airbox & filter?
and i suppose the needle is in stock position.
1980 kz1000G1
- Motor Head
Also did you check for vacuum leaks, bench set the float level when carbs were off? Bench sync the slides/ butterflies? If this is all good a running carb sync with a manometer might help.
Low voltage to the ignition coils can affect performance and starting, check that the voltage is close to battery volts, .5v difference or less is good.
- Thank you received: 2098
Are the diaphragms in good condition, no tears or holes?
Strong steady pull at WOT with no bog?
- School Teacher
Is it known which cylinder is failing to combust during the bog? I WILL LOOK INTO IT
Are the diaphragms in good condition, no tears or holes? THOSE HAVE BEEN CHECKED AND ARE GOOD.
IT NEVER REALLY GETS TO WIDE OPEN BECAUSE IT IS "SURGE" BOGGING
not yelling caps are to show difference.
thanks for everything sofar guys.
1980 kz1000G1
- Motor Head
- School Teacher
1980 kz1000G1
- Motor Head
...not yelling caps are to show difference....
:huh: ??
- School Teacher
1980 kz1000G1
