- Thank you received: 10
BS36? single carb mod
- Kitten Tooth
23 Aug 2010 19:02 #393344
by Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
BS36? single carb mod was created by Kitten Tooth
Im trying to decide what to use as a carb on my single carb switch over for the gokart... when i bought my 1981 KZ1000, it came with some carbs off of a 1982 KZ1100. I bought a stock set for the 1000 and swapped them out so now i have this extra set of carbs just sitting in a box. I was wondering, if i took cylinder 1's carb since it only has one main fuel opening, is it possible that i could make a manifold and have it function with the proper jets on my 76' KZ400 as a single carb? Its a complete carb, i just have to set that carb up with a slot for the cable on the throttle arm. Also, i have a source for a craftsman lawntractor frame and everything so the kart is on its way to the road:)
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- PLUMMEN
- Thank you received: 104
23 Aug 2010 20:14 #393366
by PLUMMEN
Replied by PLUMMEN on topic BS36? single carb mod
the lawnmower frame scares me,they dont handle very well in their intended form let alone with a loose nut behind the wheel connected to a motorcycle engine! :woohoo:
i think a smaller around 27-32mm cv style carb would work better,might be the one good place for a cv style carb in my book! :laugh:
it will rely more on engine vacuam to help control it which i think would be less of a shock on the chassis compared to cracking a slide wide open and dumping the clutch
- Kitten Tooth
23 Aug 2010 20:16 #393369
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Replied by Kitten Tooth on topic BS36? single carb mod
for the lawn mower frame, i decided that i would add a.. wheelie bar:D and extend the wheels out maybe a foot and a half for a bigger wheel base. do you guys think it would even sputter with a carb that big on there?
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- PLUMMEN
23 Aug 2010 20:19 #393373
by PLUMMEN
ask otto,hes the cv style carb guy :laugh:
