probable carb problem, looking for some opinions.
- danhalen
I have to go into work for a few hours, but after i am stopping to get some clear tubing to recheck the float height. I have messed with the idle air screws to seemingly no change. Is there a good amount of miles to run before i check plug color again? Was thinking it must be a problem with the pilot circuits as it runs great at 1/2 to wot. Just looking for some opinions, see if there's something i have not thought of.
Oh, when i pulled the plug wires off while the bikes running, there seems to be no change in idle when i pulled #4, but it idled like crap when i pulled #1, and is being shocked when you have the plug wire in your hand normal? I was wearing work boots and not touching the bike with any other part of my body......I have been shocked many a time in my day, but it seemed slightly odd. Thanks.
1980 kz550 c1
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Sounds like #4 is just not firing at idle.
yes, you can get a good shock just by holding the lead.
If you have stock airbox/filter and exhaust, then the stock mixture screw settings and fuel heights and plugs are perfectly fine.
Try this: Turn the idle down till the bike starts loping slightly (like its gonna stall), then let it idle a few minutes. Mist some water on the header pipes, and observe: If the water steam/vaporizes on a pipe, it is firing. If not, then you hav an issue that in most cases is improper vacuum syncronization, no spark, or no pilot mixture reaching cylinder, or terrible valve clearances.
Repeat the same setup with the bike idle set to 1500rpm, if all pipes steam/vaporise water mist, then you can eliminate the no spark and pilot mixture issues.
Fuel levels must all be the same, not necessarily perfectly spec, but it helps.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- danhalen
1980 kz550 c1
- danhalen
1980 kz550 c1
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- TeK9iNe
sounds like a pilot circuit issue to me i'd be pulling the carbs and going through them for sure. if it was ignition it would be breaking up really at higher rpm levels
Bingo... most likely carb issue, as current must pass thru both 1 and 4 plugs at same time to produce usable spark.
Just to be certain of course, you can pull the plug and swap it with say #3 and retry test to confirm plug is good.
Pull carbs and pop off bottoms and pull pilots. A really clean pilot can be recognised as you look through it into a fairly bright light, you should be able to see the sheen off the clean taper inside it. SUPER CLEAN :laugh:
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- danhalen
1980 kz550 c1
- danhalen
1980 kz550 c1
- Motor Head
- Thank you received: 391
How about a compression test?
Did you do a bench clear tube test of the fuel levels?
Did you use a small wire gauge to bench sync the carbs so the butterflies/ or slides are even?
Then after a running carb sync?
- danhalen
I used a similar method to check the slides with a small drill bit.
I just went to check something else before i got to the vacuum leak test, i pulled the pilot screw completely out of the opening and sprayed a few hits of carb cleaner into the pilot screw hole while it was running. I saw no change of engine rpm, although when i blasted it out with carb cleaner it sprayed out of the other holes.
Ill have to see if one of my friends has a compression tester i can borrow.
I gave the oil filler opening a quick sniff and didn't smell any gasoline though.
1980 kz550 c1
- Motor Head
Spray some carb cleaner around at the manifolds, that might show a vacuum leak.
Is the air system still hooked up? If so are the small hoses that run from the 1 & 4 carbs good no leaks?
Compression will tell the mechanical story, if a valve is tight you may have a burning of the valve face. I bought a starter shim kit for my 550 from K&L supply. Its cheaper to swap around, then order the couple of shims you need.
This won't cause your issue, but you should check the Ignition advancer, and lube it if not already done.
- timebomb33
