- Thank you received: 82
lag
- stonemaster
- Visitor
keep em coming guys, with these responses i'm formulating my punch list and order of battle, LOL
- testarossa
Also it might be worth while to check for loose wiring related to the ignition system. It's possible that you may have a wire that is moving when you accelerate away and then it returns to its normal position once in a steady state speed on the road. Intermittent contact could be causing a temporary miss.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- stonemaster
- Visitor
- mark1122
- Keep twisting it
- Thank you received: 109
went for a ride last night, bike ran fine except ... only lags/hesitates off a dead stop, and is more noticeable if I pull out of my driveway going in the uphill direction. Otherwise it runs good. With my past crab fart problems I'm reluctant to move the jet needle clip higher. It is on 4 right now and going to 3 means leaner correct?? I'm afraid it will go back to carb farting again ....opinions ????
what change did u make to get this slight improvement from the last reply?
it sounds like the pilots are lean to me.
this would be normal after adding pods. u said u turned the pilot screws in from 1 1/4 to 1 turn to stop the farting. how about turning then in some more? these are air screws right? (screws are on the motor side of the slides)this will richen the mix.
going up hill should not affect performance level due to the fuel float . pressure on floats from fuel should keep them closed.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- stonemaster
- Visitor
thanx
- stonemaster
- Visitor
- stonemaster
- Visitor
