I Need Baseline Settings. Please Advise.
- glennhudson
- Art, science & people.
20 Aug 2010 09:48 - 20 Aug 2010 09:56 #392476
by glennhudson
multiple media art * shoot & edit video * compose text & music
I Need Baseline Settings. Please Advise. was created by glennhudson
Hi.
I purchased a set of Mikuni Kogyo MIC's with the accelerator pump.
I pulled them apart to clean them.
I now need baseline settings for the item #33 (it has a spring & protrudes out the bottom of the bowl for adjusting) in the individual carb schematic, as well, baseline settings for the air/fuel mixture screw & the accelerator pump linkage.
Any input would be highly appreciated.
-Glenn
-Glenn
Last edit: 20 Aug 2010 09:56 by glennhudson.
- Thank you received: 2237
27 Aug 2010 09:41 #394242
by TexasKZ
Replied by TexasKZ on topic I Need Baseline Settings. Please Advise.
That depends on what motorcycle they are going on, whether it is stock or modified, and how the carbs are currently jetted.
- PLUMMEN
- Thank you received: 104
27 Aug 2010 16:58 #394360
by PLUMMEN
Replied by PLUMMEN on topic I Need Baseline Settings. Please Advise.
1 1/4-1 1/2 turns from seated is generally a good starting point 10.7-10.9mm of thread under nut on pump rod
- TeK9iNe
- What did you do!?!
- Thank you received: 28
27 Aug 2010 19:00 #394410
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic I Need Baseline Settings. Please Advise.
PLUMMEN wrote:
:ohmy: :laugh:
... under nut on pump rod
:ohmy: :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- PLUMMEN
27 Aug 2010 19:06 #394414
by PLUMMEN
- glennhudson
29 Aug 2010 22:55 #394934
by glennhudson
Replied by glennhudson on topic I Need Baseline Settings. Please Advise.
sounds good plummen.
the air/fuel stating point i recently found and it matches what you've suggested.
that bit about the pump rod linkage sounds good as well.
i may call kaw factory for input about that adjustable item that protrudes through the bowl, adjustable bottom side.
i now believe its called the, "pilot screw".
texaskz, its an '80 ltd chassis, an '81 (maybe a "J") motor.
