carb sync and tune 440
- mooney
18 Aug 2010 19:58 #392025
by mooney
carb sync and tune 440 was created by mooney
Ive got an 81 440 and am having balancing and tuning problems. If you can think of the problem ive got em. first off im having trouble setting the fuel level in the bowl. it seems that I can try and level them on the bench and i cant get the level high enough then i put them on the bike and they start leaking like crazy.
How sensitive are these carbs to the fuel level in the bowl?
Next problem, both carbs seem to run (roughly) when it is above idle. yet when they get close to idle one cylinder drops out and it dies.
Another, I thought i should try to sync or balance the carbs, using clear tube and some antifreeze as a bright colored liquid i could easily see. The outcome was one carb would suck so hard the antifreeze would be sucked right into the vacuum port. so i tried adjusting back and the other carb sucked the antifreeze in. haha im at the end of my rope.
Basically the darn things just wont idle. All the things listed above are things ive done to try and make them idle. Theyve been cleaned (at least 10 times) and kitted. ive made sure all jets and holes are clean and flow fuel.
They DO have pods, which i know is evidently a real trouble maker. but it seems if one side runs on idle i should be able to get them to both run idle.
Im going crazy, brb im going to go curl up in a ball in my shower and cry. :side:
- Nebr_Rex
- Thank you received: 300
18 Aug 2010 21:41 #392056
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic carb sync and tune 440
how are your plugs?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- mooney
18 Aug 2010 22:04 #392058
by mooney
Replied by mooney on topic carb sync and tune 440
brand new plugs coil and contact points. just checked the compression with some bad news. right cylinder 120, left only 105. yet the low compression cylinder is the one that tends to run better.
