- Thank you received: 10
1976 KZ400 over flowing and idling aweful
- Kitten Tooth
18 Aug 2010 07:59 #391879
by Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400 over flowing and idling aweful was created by Kitten Tooth
I went to the garage 2 days ago with my dad to work on his Cafe racer KZ400. It sat for about 2 months and i had accidentally poured in 2 stroke fuel mix in the tank. So not only was the gas old, it was... 2 stroke. Anyway, i dumped the 2 stroke stuff out of the tank and removed the carbs. About a 5 minute job because the carbs are set up for pods so you can just pop them off. I brought them home, popped the bowls off, removed the main jets, emersion valves, pilots, top caps, constant velocity pistons, and i kinda just disassembled them all the way down. I know that when you separate carbs like that, they go out of sync but on of carbs the butterfly was damaged, and the throttle shaft was broke as well. So, i replaced the broken parts with clean used working ones and put everthing back together. I could tell by my eyes that they were WAY out of sync. I adjusted the little lock nut and set screw so that the butterflies looked mostly level. I then installed the carbs in the bike, hooked up the throttle cable, put on the fuel line, hooked up a battery and put some gas in the tank. I hit the starter button with it on full choke and it fired right up but it idled kinda high and it wouldn't revv. When you pulled the throttle back, it would revv to my guess being like 4000 RPM since there is no Tach on the bike at the moment, and then it would just level out and kinda sound like it was drowning or something.
Also, there is a large ammont of gas pouring out of the overflow on the bowl.. any ideas?
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kawickrice
- Thank you received: 18
18 Aug 2010 09:28 #391896
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic 1976 KZ400 over flowing and idling aweful
Gas pouring out of the overflow would be stuck floats or the float level is out of whack. Pull the bowl and see if any trash is in the needle seat area then set the float level. If its running you are getting close.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- TerryK
- Thank you received: 3
18 Aug 2010 11:08 #391907
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic 1976 KZ400 over flowing and idling aweful
Stuck float(s). Tap on the float bowls with the plastic end of a screwdriver until the fuel stops over flowing.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- Motor Head
- Thank you received: 391
18 Aug 2010 13:57 #391939
by Motor Head
Replied by Motor Head on topic 1976 KZ400 over flowing and idling aweful
KT, you didn't swap around the float needles or the floats themselves did you. The needles would be worn to their individual seats. And moving the floats would then require resetting float level/ fuel level in bowls. Also when you were pouring in the Mix at first, was a inline filter installed between the tank and carbs? The old gas might have had debris?
- Kitten Tooth
18 Aug 2010 15:36 #391953
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Replied by Kitten Tooth on topic 1976 KZ400 over flowing and idling aweful
The old needles had rubber tips on them.. When i got the bike it wouldn't run without starter fluid and it would only sputter for a second each time you started it. I removed the float bowls only to find that the needles were stuck in the seats because of the rubber tips. I tried to re-use them but they kept getting stuck. So, i used some old float needles from an XS1100 and put everything back together. When you blow air through the fuel hose going into the carb while the carbs are rightside up, air blows through. When you turn them upside down you cannot blow air through. So, the needles are seating properly. Floats are stock, i didn't swap them out with anything else. Those could be sticking maybe... I'll find out when i go back to the garage on Saturday.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
