- Thank you received: 10
CR125 single carb on a KZ400?
- Kitten Tooth
12 Aug 2010 20:18 #390509
by Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Replied by Kitten Tooth on topic CR125 single carb on a KZ400?
still pretty awesome:D if i found that in a garage, i would be drooling over it.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
12 Aug 2010 22:14 #390520
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Stay tuned, im gonna have a video up of the carburetors in about 3 minutes. Sorry guys, i don't have a picture camera so I just video tape stuff instead.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
12 Aug 2010 22:19 #390521
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- The Milkman
- Thank you received: 194
13 Aug 2010 18:14 - 13 Aug 2010 18:19 #390735
by The Milkman
Replied by The Milkman on topic CR125 single carb on a KZ400?
I put a single carb on a 650. I am using a Stromberg 150 off a triumph car.
I use 1 inch copper tubing for the manifold. Have had it on for 3 years now. Still working fine.
I'll see if I can find a link for it in archives and post it here.
Here is a link for one of the posts.
kzrider.com/archive/viewthread.php?tid=23259#pid202587
Last edit: 13 Aug 2010 18:19 by The Milkman.
- Kitten Tooth
13 Aug 2010 18:56 #390746
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Damn that carb is burly looking
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- kennewick58
16 Aug 2010 22:17 - 16 Aug 2010 22:32 #391557
by kennewick58
Replied by kennewick58 on topic CR125 single carb on a KZ400?
Popular mod on the Kaw twin forum Some dude from England has experimented with the single carb on the 400/440 and the consensus is that anything bigger than a 35mm is too big. As in too hard to jet down. I would think that from a 32 to 35 would be ideal. I have been looking for a set of 35's for my 2 440's. As for the lean condition it is a none issue as the cylinders will suck what they need from the manifold. The design they were using had the carb at about a 60 degree angle instead of the 90 deg in the video. I like the 90 degree set up as it dumps the mixture right in the middle of the manifold. warning this thread is full of info and real long.
www.armbell.com/forum/viewtopic.php?t=32...start=0&mforum=kz400
Last edit: 16 Aug 2010 22:32 by kennewick58.
- Kitten Tooth
17 Aug 2010 03:44 #391574
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
I found a 32mm on ebay that i think ill use for sure. Where do you guys get those air filter screen things? i may need one..
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- kennewick58
17 Aug 2010 07:46 #391622
by kennewick58
Not sure of where they got the screens but My concern is filtration. I want to look at a small round chrome airfilter housing. Might look real good in that location also. I have some parts bikes to play with, I'll get back.
