Float for the carb
- farixrc
09 Aug 2010 11:25 #389611
by farixrc
Float for the carb was created by farixrc
Looking for a carb float for my 79 kz750. The one in there is dented. I cant seem to track any down. It has the stock carbs on it. Thank you for your time.
- Thank you received: 2098
09 Aug 2010 15:44 #389696
by Patton
Replied by Patton on topic Float for the carb
farixrc wrote:
How badly damaged?
Possibly repairable?
Pic?
Per kawasaki.com, the same float (Part No. 16031-030) was fitted to 13 models (see below).
KDX250-B2 (KDX250) (1982)
KDX250-B3 (KDX250) (1983)
KDX250-B4 (KDX250) (1984)
KX250-B1 (KX250) (1982)
KX250-C2 (KX250) (1984)
KX250-E1 (KX250) (1987)
KX500-C1 (KX500) (1987)
KXT250-A2 (Tecate) (1985)
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
KZ750-G1 (LTD II) (1980)
How badly damaged?
Pic?
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
- farixrc
24 Aug 2010 05:31 #393418
by farixrc
Replied by farixrc on topic Float for the carb
Still not having any luck. Anyone else have any ideas? Thank you.
- Thank you received: 2829
24 Aug 2010 05:56 #393422
by 650ed
Replied by 650ed on topic Float for the carb
I know you said "stock", but exactly which carbs on on the bike? Ed
24 Aug 2010 06:07 - 24 Aug 2010 06:08 #393423
by Patton
If not already done, might want to check with Sudco at its website.
Last edit: 24 Aug 2010 06:08 by Patton.
- TeK9iNe
- What did you do!?!
24 Aug 2010 07:12 #393435
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Float for the carb
If it still floats, and doesnt fill with gas, then use it. you will have to test to make sure you can still obtain correct fuel height, and if so, then its fine.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
