- Thank you received: 48
carb parts
- stonemaster
- Visitor
- JMKZHI
- stonemaster
- Visitor
- chance
- Life long biker/
- stonemaster
- Visitor
- Thank you received: 2098
I have discovered the PO over tightened and bent the needle jet # 16017-064 and marred the the needle jet holder # 16947-002. I need three of each, PM please
stonemaster wrote:
...need needle jets for mukuni vm 28 carbs, off a 73 Z1 900 , the other part is the needle jet holder....
Am not seeing these part numbers on kawasaki.com which shows:
21 16009-055 JET NEEDLE 5J9
23 16017-086 NEEDLE JET,0-8
See image below.
[Click on image to enhance view.]
- stonemaster
- Visitor
stonemaster wrote:24 is the needle jet 23 is needle jet holder, that is from my parts catalog....
For all Z1, 1973, 1974 and 1975, kawasaki.com identifies these parts as:
24 16047-003 HOLDER,NEEDLE JET
Am thinking needle jet #23 press fits into the carb body, and that #24 jet needle holder is aka bleed tube.
However, Z1E's listing for Z1 needle jet limits its application: Fits Kawasaki Z1/A through frame number 32817 - these carbs are the ones with the 17mm drain plug directly under the main jet.
Click here > Z1E's early Z1 carb needle jet
If not already done, would ask Z1E about needle jet for later Z1 carb and possible availability through Z1 from another supplier (maybe Sudco).
- roy-b-boy-b
- Thank you received: 103
They are very helpful. roy
To install your bike in your signiture click on my profile.
It's up there near the top of the page. Roy
- stonemaster
- Visitor
stonemaster wrote:
sorry got it reversed, lost my glasses this morning, thanx for the link, thats half my problem solved,needle jet # 16017-064 and marred the the needle jet holder # 16947-002
I tried Sudco, (who actually still had it on their list but no longer available) I'll check again at Z1 ent, I have the worst trouble with their search function. good people though
ps; I just copied and paste the needle jet part number on Z1 ent site search box and NOTHING. WTF ????
- stonemaster
- Visitor
