KZ1000 jet questions
- 55fbomb
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
- Nebr_Rex
- Thank you received: 300
Hello, been lurking and using the search function for a couple days but cant really find the answers im looking for. i finally bought a KZ1000, its a 78 and im planning on running an open 4-1 and a set of pods or a breadbox aircleaner. can anyone give me a baseline of where i can start the jetting process? im not too familiar with KZs, this is only my third one and i didnt have the other 2 very long but i intend on keeping this one. most of my experience is with Honda SOHC bikes, so i apppreciate any help.
what carbs are you using?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- 55fbomb
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
- Old Man Rock
- Thank you received: 225
This zipped file covers pretty much everything you need to know regarding carb theory, operations, JETTING, trouble shooting and extremely important Spark Plug reading....
Carb Manual & Theory:
kzrider.com/index.php?option=com_docman&...d&gid=461&Itemid=108
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2098
1978 KZ1000-A2 (standard) Mikuni 26mm VM26SS 105R main and 15 pilot
1978 KZ1000-D1 (Z1R cafe racer) Mikuni 28mm VM28SS 107.5R and 15 pilot
Before any jet change, would perform throttle chop test with plug readings.
Would continue using the stock airbox.
Maybe with a K&N filter if preferred.
Actually, a fresh oem paper fold air filter flows almost as much air, and with superior filtration.
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- chance
- Life long biker/
- 55fbomb
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
- 55fbomb
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
- Quadzilla
I'm getting ready to buy a stock '79 KZ1000E1 w stocks carbs and exhaust. According to one post above, the E1 (shaft drive) version comes with a larger main jet than the other models.
If I want to put an aftermarket 4 into 1 pipe on her, what would you recommend jetting her with?
Thanks!
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
try the same jetting that chance recommended above it will be very close.
Yea!
Welcome Home, TB!
