air filters
- JARHEAD76
06 Aug 2010 18:52 #388803
by JARHEAD76
air filters was created by JARHEAD76
Hi Guys, tried to start 82 kz1100 with no boots or filter. Im beginning to think carb boots and air cleaner has to be on for accurate running. Boots were a pain the first time[so left off] I tried and the filter was trashed[one ordered].
- TerryK
- Thank you received: 3
06 Aug 2010 19:39 #388820
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic air filters
If everything is set up and working properly, it should bark right up without the airbox/boots. Just don't ride it like that if you can help it.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- Thank you received: 2829
06 Aug 2010 19:57 #388824
by 650ed
Replied by 650ed on topic air filters
New boots are very pliable and MUCH easier to install than old hard boots. I believe it will run like crap (too lean) if it runs at all with naked carbs. Ed
