- Thank you received: 5
Ultrasonic carb cleaning
- dshelly
06 Aug 2010 14:01 #388723
by dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Ultrasonic carb cleaning was created by dshelly
Hi everyone,
I just picked up an ultrasonic cleaner on craigslist recently for cleaning carbs. So I was wondering if any of you guys use one of these to clean carbs. What kind of solution do you use? and where do you get it?
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- mjg15
06 Aug 2010 14:09 #388726
by mjg15
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
Replied by mjg15 on topic Ultrasonic carb cleaning
Just use Simple Green and water. I usually remove the jets and diaphrams and put the bowls back on. I've had clogged pilots jets that didn't come clean a couple times so now I clean the jets separately by soaking them in paint brush cleaner.
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- mjkawa
06 Aug 2010 14:15 #388729
by mjkawa
82 KZ-1000-J
77 KZ650 B
Replied by mjkawa on topic Ultrasonic carb cleaning
I have done a couple of sets of carbs in mine, and also used simple green and h2o. It worked very well.
Good thing about ultrasonic is that it doesnt harm brass, or rubber parts, like some chemical cleaning techniques do.
Make sure that you have a basket of some kind so that your parts are not resting on the bottom of the tank where the ultrasonics are coming from.
MJ
MJ
82 KZ-1000-J
77 KZ650 B
- dshelly
10 Aug 2010 17:08 - 10 Aug 2010 17:09 #389960
by dshelly
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Replied by dshelly on topic Ultrasonic carb cleaning
Simple green Huh? Whats that do as far as the finish on the body itself? I also want to brighten up the outside. Make them purty , you know.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Last edit: 10 Aug 2010 17:09 by dshelly.
- stonemaster
- Visitor
10 Aug 2010 17:16 #389962
by stonemaster
Replied by stonemaster on topic Ultrasonic carb cleaning
soda blaster
