- Thank you received: 1
long warmup
- ace
- 78kz1000
06 Aug 2010 05:37 #388591
by ace
78kz1000
long warmup was created by ace
my 78 kz1000 takes forever to warm up... i start it with choke,kick it down to like 2grand and wait like 5- 10 mins till it holds its idle at 1 grand.. is this common??? by then shes all set & runs perfect. my carbs are clean & jetted& my fuel lines are filtered.im not sure if its related but my coils are original and im thinkin of replacing them. any ideas out there???
78kz1000
- Motor Head
- Thank you received: 391
06 Aug 2010 06:56 #388612
by Motor Head
Replied by Motor Head on topic long warmup
Which carb's do you have? Seems like a long time to me, maybe a vacuum leak? How many turns out are your Idle mixture screws? Maybe a bit richer here would help?
- ace
- 78kz1000
06 Aug 2010 10:20 #388646
by ace
78kz1000
Replied by ace on topic long warmup
not sure exactly/ mikunis i believe... prolly factory carbs for a 78. i will check the boots for leaks but i dont think its that cuz once shes warm she runs like a bear. its got emgo pods& a star racing header as well,also shes got about 40k on the clock. maybe its time for a rebuild??? i had a big block caddy,did the same thing.....took awhile to warm up,then watchout!!!! thanx for the advise.
78kz1000
- Motor Head
06 Aug 2010 10:26 #388650
by Motor Head
Have you synced the carb's? They will be rougher when cold, and maybe with the pods you might be a bit lean. Try moving your Needles to lift them 1 notch. This may make it run a bit better cold.
- ace
- 78kz1000
