Extended swingarm
- baborz72
- Not enough hours!
Extended swingarm
04 Aug 2010 16:27
I've never extended a swingarm. I'm a fairly talented fabricator with equipment. Can anyone send me pics of the un-installed finished product so I can kind of copy it? I know I want to extend it. I used to watch the guys ride these bikes @ the dragstrip when I used to race cars and they are quick to go vertical...I don't want to go vert. May even ride around with wheelie bars...lol..
.. after all(to quote Kid Rock): It aint braggin' mother f&%#er if you back it up....I don't know....I do like to crank that throttle from time to time.
It'll go...or...It'll blow!
- hocbj23
Re: Extended swingarm
04 Aug 2010 16:56
why reinvent the wheel (or wheelie as it were).Just buy one of the lovely Zuki GS1100 arms off FleaBay and section it if u need a longer arm.The stock GS arm gives u 2 more inches of length and drops the bike 2 inches.U can go from there.More work may be needed if u have a drum brake in the rear,but otherwise its a drop in swap.My bike with the stock GS arm will lift the front wheel a little on a hard takeoff but otherwise it is very stable.bj
- baborz72
- Not enough hours!
04 Aug 2010 18:02
Awesome....Thanks man!....
- baborz72
- Not enough hours!
04 Aug 2010 18:26
Now, does that also provide for a wider wheel/tire combo?
- baborz72
- Not enough hours!
05 Aug 2010 10:28
Are any of the gs1100 swingarms chain-drive? My kz is an older chain-drive model and all I'm seeing for sale is shaft models.
- TerryK
05 Aug 2010 10:30 - 05 Aug 2010 10:40
Isnt it the GS1000 he needs?, And look for an aluminum one, not a steel one.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 05 Aug 2010 10:40 by TerryK.
- StreetfighterKz
05 Aug 2010 11:13
baborz72 wrote:
Look for an 'arm from a Gs1100E model.
baborz72 wrote:
With the right rim/sprocket combo you can squeeze a 180mm tire in there but most people stick with a 160mm tire on a 4.5" wide rim.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- hocbj23
- baborz72
- Not enough hours!
05 Aug 2010 19:29
Awesome! Thanks for the input ...By the way I got to hear the bike run tonight.
- donthekawguy
05 Aug 2010 19:31
Here is what your looking for.
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...me=STRK%3AMEWAX%3AIT
Item number 110547568286 great price too.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- baborz72
- Not enough hours!
05 Aug 2010 19:37
But what if you want to go out further??? 4-6" for instance...
