vm 26 throttle shaft grommets
- oppie501
02 Aug 2010 07:19 #387623
by oppie501
vm 26 throttle shaft grommets was created by oppie501
Hey guys, I have a 76 kz 900 with vm 26 carbs. The throttle shaft grommets are pretty dry rotted. I would like to replace them during my carb rebuild, but can't find them. Tried all popular spots, z1,carb warehouse. the parts are deleted through kawasaki. Any help locating aftermarket would be greatly appreciated. How critical are these? I would like to keep rain and dirt out of my new carbs, but am drawing a blank on finding them.
Thanks,
Mike
Thanks,
Mike
- Motor Head
- Thank you received: 391
02 Aug 2010 07:37 - 02 Aug 2010 07:50 #387626
by Motor Head
Replied by Motor Head on topic vm 26 throttle shaft grommets
Vacuum seals for your throttle shafts, very important!
Had a hard time sourcing these for a buddies bike, tried some small O-rings but the throttle would hand slightly. Finally found the correct parts, but that was 10 years ago. They must be sold somewhere????? Anyone?
EDIT: Try these guy's?
www.motorcyclecarbs.com/About_Mikuni_OEM...ies_4_C_W142C555.cfm
Maybe?
Maybe?
Last edit: 02 Aug 2010 07:50 by Motor Head. Reason: LINK
- dshelly
- Thank you received: 5
02 Aug 2010 08:02 #387632
by dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Replied by dshelly on topic vm 26 throttle shaft grommets
Call Jim @ redline cycle services (847) 675-2020. They usually have some of these for the restorations they do.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
