1980 KZ650 CARB.FLOAT SETTING
- ronnie chabot
01 Aug 2010 18:41 #387538
by ronnie chabot
1980 KZ650 CARB.FLOAT SETTING was created by ronnie chabot
HI
NEED TO SET FLOATS ON A STOCK KZ650 CARBS
FOR A FRIENDS BIKE.
ANYONE TELL ME THE SETTING.
THANKS RONNIE
FOR A FRIENDS BIKE.
THANKS RONNIE
- Thank you received: 2098
01 Aug 2010 19:07 #387545
by Patton
Replied by Patton on topic 1980 KZ650 CARB.FLOAT SETTING
ronnie chabot wrote:
Typical float setting is tang position that maintains fuel level at 2~4mm below carb body.
Clear tube test is best method to assure fuel level.
Example shown below is Mikuni 29mm smoothbore carb.
[Click on image to enlarge view.]
HI
FOR A FRIENDS BIKE.
THANKS RONNIE
- Bluemeanie
- Thank you received: 14
02 Aug 2010 06:33 #387606
by Bluemeanie
Replied by Bluemeanie on topic 1980 KZ650 CARB.FLOAT SETTING
Same as he said about the clear tube method but with a different pic...
This is on ebay for about $11 including shipping. Works excellant!
02 Aug 2010 06:46 #387612
by Patton
Bluemeanie wrote:
Here's an amended image extending line to float needle.
02 Aug 2010 06:50 #387615
by Patton
- ronnie chabot
06 Aug 2010 16:35 #388752
by ronnie chabot
Replied by ronnie chabot on topic 1980 KZ650 CARB.FLOAT SETTING
hi
got the floats set
thanks for all the help
ronnie
got the floats set
ronnie
