Gas tank leaking from the welded seams
- mwhaley
29 Jul 2010 12:06 #386810
by mwhaley
Gas tank leaking from the welded seams was created by mwhaley
:woohoo:
I know the usual gas tank leak issues as discussed on the board (PC and or Gas Cap) but I have a 1974 KZ 400 and the gas is leaking slowly but surely out of the welded seams on the bottom of the tank. My neighbor actually has a 75 KZ 400 and his is doing the same thing. He says it only happens in the summer on his. Anybody else had this problem and what are the best fixes? Mine is still a project so no new paint yet and I was thinking maybe having a new weld put on or somehow trying to seal the current weld.
- Old Man Rock
- Thank you received: 225
29 Jul 2010 12:16 - 29 Jul 2010 12:20 #386812
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Gas tank leaking from the welded seams
I used the Kreme 3 part tank restoration (cleaner, Prep/Etcher & Sealer) on my 900 tank...
I live in Arizona where temps reach 115F in the summer... No problems and in my second summer....
Same time.... I guess it depnds on the condition of the seams...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 29 Jul 2010 12:20 by Old Man Rock.
- mwhaley
29 Jul 2010 12:36 #386817
by mwhaley
Replied by mwhaley on topic Gas tank leaking from the welded seams
I guess i was trying to avoid doing that since the inside of the tank has no rust or any other issues. I may have to resort to that especially knowing you've had no problems in Arizona it's just not my first choice.
- Old Man Rock
29 Jul 2010 12:39 #386818
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Well I guess you could always get the seams grounded and re-welded but kiss your paint job goodbye....
Maybe some of the others have found an external product that works......
Hell, Otto the Mad Chemist should know of something I would think....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Iron Duke
- what are you rebelling against?
29 Jul 2010 12:39 #386819
by Iron Duke
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
Replied by Iron Duke on topic Gas tank leaking from the welded seams
Seal/reline the tank is only dollar wise way, good luck Duke
1982 KZ550 LTD C-3
- Kawickrice
- Thank you received: 18
29 Jul 2010 12:42 - 29 Jul 2010 12:45 #386820
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic Gas tank leaking from the welded seams
If you want a quick fix that is temporary you could try some epoxy putty. I used some in an emergency 150 miles away from the house and its still there after two years. Might not be the right way but it is quick and easy to do and not messy at all.
My.02 cents
Easy to mix - Stops leaks, makes repairs fast - Begins to harden 2 min. after mixing - Fully hardens in 20 min. - Can be drilled, filed, tapped, sanded and machined after one hour - Can be painted even before full hardening - For plumbing, bathroom, underwater, auto repairs and custom formed gaskets
My.02 cents
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Last edit: 29 Jul 2010 12:45 by Kawickrice.
