kz440 pods? is it possible???
- mooney
- otakar
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- JMKZHI
- Thank you received: 48
Someone here installed some late model ATV carburetors w some success, using one pod filter connected to a homemade intake manifold.
Here's the topic w pics: My Custom Bobber 440 .
And here's a quote:
harm-
Thanks for the good comments! The manifold was made using copper tubing, I believe 1.5" diameter. I took 3 90's and brazed them together. I'll post pic tonight.
The carburetor is a mikuni cv off of a 2004 kfx400 atv. I added larger jets and shimmed the needle. I need to get a bigger pilot jet for the cold mornings. When it's cold, the lower rpm stutters a little. When bike is warm, it runs great from idle to wot and will rev about 1000rpm higher than with factory jetted carbs.
It has digital ignition, so the timing is more or less fixed. I plan on oblonging the holes on the mounting plate to advance the timing to tune further.
