- Thank you received: 2
Leaking CV34
- kz750saskatoon
There is a constant drip of fuel out of the overflow tube on carb #4. If I set the petcock to ON (petcock is ON-PRIME-RES type) and leave the bike overnight, when I come to it in the morning if I take the #4 overflow tube out of the airbox it is filled with fuel.
Things I have done/tried:
1) float bowl gasket is new as is float needle and drain screw o-ring
2) I used the clear-tube method to check fuel level and it is approximately 4mm below the float bowl gasket.
3) Used a spare float bowl with same drain screw
4) Used same float bowl but swapped drain screws between carbs. Carb #4 still leaks.
5) Held float bowl up to carb body as I turned petcock to prime. After a minute or so (wanted to make sure it filled) I turned the petcock back to ON and carefully removed the float bowl. It was nowhere near the top of the overflow tube. I held up the float bowl at eye level and there was a drip out of the overflow/drain nipple
6) Brought float bowl up to house and put water into it until just below the top of the bowl. No drip out the bottom
7) Inspected tip of float needle for imperfections and there were none visible
Cleaned out seat of float needle by a) cotton swab and b) putting bowl below carb and opening fuel wide open
#5 would lead me to believe the float needle is working properly. #4 leads me to believe it is not a problem with the drain screw. #3 leads me to believe it is not a problem such as cracked overflow tube.
I am completely stumped. I feel like I have exhausted every possibility yet I still have an issue. Any ideas?
1981 KZ750-H2
Saskatoon, SK
- Thank you received: 2098
...There is a constant drip of fuel out of the overflow tube on carb #4. If I set the petcock to ON (petcock is ON-PRIME-RES type) and leave the bike overnight, when I come to it in the morning if I take the #4 overflow tube out of the airbox it is filled with fuel...
5)...was nowhere near the top of the overflow tube...was a drip out of the overflow/drain nipple.
Are the correct drain screw 0-rings fitted, and in good condition?
...if I take the #4 overflow tube out of the airbox it is filled with fuel.... :huh:
Am thinking the carb drain hoses are routed from the float bowl nipples to exit underneath the bike, and without going into the airbox.
- JR
- Thank you received: 449
On the CV34 the drain screw and the overflow tube are connected and gas comes out the nipple on the bottom.
My suggestion. Take the bowl off. Connect a clear tube to the nipple. Fill the bowl with water. Put your finger over the top of the brass overflow tube and blow into the clear tube. I've done this . This would be the equivalent of looking for a slow puncture in a bicycle inner tube. If you get bubbles then you can narrow it down to the screw or brass tube.
If no bubbles then it has to be the float vavle or seat. To clean the brass seat (they are not replaceable on the CV34) use a cotton Q tip dipped in carb cleaner or better yet Brasso and then carb cleaner. Put the float and valve back on. Turn the carbs upside down and blow into the fuel line to check the operation of the valve. float valve tips and seats can look good but ot only takes a microscopic piece of dirt to screw it up... which reminds me - you do have a fuel filter ?
Best of luck. You'll get it figured out and it will be worth it in the end.
- apbling
- Thank you received: 12
As a side note, I bought new, longer drain lines for my bike. I didn't like the idea of the overflow going into the airbox, where it would take me longer to discover an issue. I just routed them all out the back like my 550.
- kz750saskatoon
I used the O-rings form the carb kit sold at Z1. The rest of the O-Rings were pretty obvious as far as where they went so I am pretty sure I got these ones right. I put the same o-rings on all 4 drain screws and its only #4 that leaks.
Also, on the KZ750 the overflow tubes are routed to a Y which fits into a grommet on the bottom of the airbox.
JR:
Checking by blowing into the bowl is perfect. I was trying to think of how to accomplish something like that. Brain was blocked by frustration. One question though. If I do put the whole carb together and flip it over as you suggest, wouldn't I still get air movement due to all the jets and such? I guess it will just be far more restricted flow.
apbling:
I will give that a try I guess if the above doesn't get it fixed. The float needle is new new. The floats themselves are not.
I'm real confused about this all. When I removed the float bowl after letting it fill up, the fuel level was nowhere near the top of the overflow tube.
Oh well, more testing. Thanks guys. I'll have an update this evening.
1981 KZ750-H2
Saskatoon, SK
- kz750saskatoon
I guess the brass tube has a hairline crack. What are my options then?
1981 KZ750-H2
Saskatoon, SK
- apbling
- kz750saskatoon
I had a mishap with a seized mixture screw that resulted in the tower they screw into cracking in half. Found a farmer near here with a barn filled with 80s Japanese bike parts. Found a full set of CV34s in about 10 minutes.
I have a soldering iron for electronics work. I was wondering if I could just solder it but JB Weld sounds easier. Anybody else with suggestions?
Also, once I knew where to look on the tube it was easy to see the hairline crack. Damn thing!
1981 KZ750-H2
Saskatoon, SK
- apbling
If you are good at soldering, I bet that would be the way to go. I just can't solder to save my life, so I wouldn't have even considered it for me!
JBWeld;
Solder;
Snug fitting flexible tube over cracked tube;
Close fitting brass tube (from hobby shop store) fitted over cracked overflow tube, and soldered in position;
Heat-shrink tubing over cracked overflow tube.
- JR
You're getting there !
Options - I used JB Weld on one cracked overflow tube. Just make sure you let it cure overnight or better yet 24 hours.
On another. I went to a hobby shop with bowl in hand and found thin brass tubing with an internal diameter which would just slip over the overflow tube and soldered it at the bottom where it met the bowl body.
Whatever you end up doing check that the repair does not interfere with the operation of the float before you reassemble the carb
JR:
No. When you blow into the fuel line the air has to go via the float valve. With the carb upside down and the float valve seating correctly you will find there is a surprising resistance to blowing. Try it
Good luck
- kz750saskatoon
About 5 hours ago I put some JB Weld over the crack. Tube says to let it cure for 16-24 hours. I am tempted to put it back on tomorrow morning. I think I will run a water and blow (sounds dirty...) test in the morning and see how it goes.
1981 KZ750-H2
Saskatoon, SK
