Need some help - 1995 KZ1000P Carb
- ddmcnair
26 Jul 2010 15:18 #386001
by ddmcnair
Need some help - 1995 KZ1000P Carb was created by ddmcnair
Folks,
Just opened a set of KZ1000P and found that there are no plugs in the tubes that hold the low speed jets. You can see a picture of where they should be at:
picasaweb.google.com/lh/photo/oeoT1qbEIM...ITYw?feat=directlink
Anybody know where I can find a set of these plugs? They are metal with an O ring to seal the tube.
Thanks in advance for your help,
Doug
Doug
- TeK9iNe
- What did you do!?!
- Thank you received: 28
28 Jul 2010 12:02 - 28 Jul 2010 12:03 #386595
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Need some help - 1995 KZ1000P Carb
What happened to the plugs??? Was everything running ok like this?? I guess not right...
You can use anything really, so long as it will stay in there.
If you absolutely must have OEM, then Cycle Parts Nation is a good place to look. They have lots of microfiche parts diagrams, and ship faster than the Kaw dealers.
GL.
PS. I believe those are Mikuni BS34 Carbs.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 28 Jul 2010 12:03 by TeK9iNe.
- ddmcnair
29 Jul 2010 07:51 #386758
by ddmcnair
Replied by ddmcnair on topic Need some help - 1995 KZ1000P Carb
Thanks, Tech9.
New set of carbs to me and I can't figure out what happened to the plugs (why they weren't in the carbs). Guy said they ran well except popped a little on idle but who knows.
Thought about threading the top of the tube and putting in a stainless bolt but decided to buy a set instead because of the Oring/check valve whatever that is. Found Ron Ayres ( www.ronayers.com/ ) was a much better deal than Cycle Parts Nation who wanted more for the plugs and O rings and wanted $19.20 to ship them (vs. 5.00). I used to buy from Cycle Parts Nation when they charged real shipping fees.
- idahojoe
16 Aug 2010 23:17 #391562
by idahojoe
Replied by idahojoe on topic Need some help - 1995 KZ1000P Carb
I lost one in my kz1100 when i was cleaning the carbs just went down to the home depo and got a oak dowl the right size and put it in. It has been in there for close to 9500 miles and no problems yet
