Kz440 rpm problem
- gabeb123
24 Jul 2010 17:48 - 24 Jul 2010 17:51 #385362
by gabeb123
1982 kz440 A3-D4
Kz440 rpm problem was created by gabeb123
I have a 1982 kz440 that will rev good when in is in nuetral but will only rev up to about 5k when it is in any other gear and i can only get it up to 50 mph. it runs pretty rich but i dont know if thats the problem.
im not sure if this is a carb issue or a electrical issue.
it has good compretion(150psi) and the air mixture screws are adjusted as good as i can get them without the equipment to sync them.
ive cleaned the carbs really good.
ive allso changed the oil and the oil filter.
thanks
thanks
1982 kz440 A3-D4
Last edit: 24 Jul 2010 17:51 by gabeb123. Reason: added info
- Thank you received: 2098
24 Jul 2010 18:20 #385380
by Patton
Replied by Patton on topic Kz440 rpm problem
Hello, gabe, and WELCOME to KZR!
We're glad you're here!
Would check function of the advancer by using a strobe type timing light to watch the advancer quickly move back and forth as rpm is varied by blipping the throttle.
The advancer may require lubing, or maybe both cleaning and lubing.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
24 Jul 2010 18:29 #385389
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Kz440 rpm problem
Good info...
You say it runs rich? What indications are you observing?
Does this bike have all the origional jets/airbox/filter/exhaust? Any major parts changes like different cams?
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- gabeb123
24 Jul 2010 18:42 - 24 Jul 2010 19:21 #385408
by gabeb123
1982 kz440 A3-D4
Replied by gabeb123 on topic Kz440 rpm problem
the spark plugs are black and to the best of my knowlede everything is stock
the advancer unit was seized up but i didnt have a gear puller so i couldnt take it out so i used about a can of wd40 on it and then my dad told me to pry the movable parts with a screwdriver and i did that and i think i broke something on both sides but i still have the same problem but now you can see the advancer unit work how its suposed to and i have a strobe but i have no clue how to use it.
1982 kz440 A3-D4
Last edit: 24 Jul 2010 19:21 by gabeb123.
