- Thank you received: 12
air jet removal, 29mm
- lewisj
23 Jul 2010 13:44 #384990
by lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
air jet removal, 29mm was created by lewisj
Hey guys, need some help. I am rebuilding some 29mm smoothbores. All is going great,but I am worried about replacing the tiny air jets (part number BS 30/97 .09).
Is there a secret to getting these little buggers out?
Thanks for any help.
Jim
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- larrycavan
- Visitor
23 Jul 2010 15:23 #385010
by larrycavan
Replied by larrycavan on topic air jet removal, 29mm
lewisj wrote:
The correct fitting screwdriver is the key.
You can spray some liquid wrench down in the passage and let it soak over night to help you out.
Don't round the heads off on those jets whatever you do.
If you can't get them out, pull the needle jets out and spray carb cleaner through the air jet, then blow it out with compressed air.
Jim
- lewisj
23 Jul 2010 15:26 #385011
by lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Replied by lewisj on topic air jet removal, 29mm
Thanks Larry! I figured as much but thought I would ask first.
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- Jeff.Saunders
23 Jul 2010 18:26 #385087
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic air jet removal, 29mm
I sacrificed a much larger flat blade screwdrive to grind down the sides of the blade to exactly the right size.
Z1 Ent on Facebook,
- lewisj
23 Jul 2010 19:02 #385097
by lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- lewisj
23 Jul 2010 19:05 #385099
by lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Jeff,
I did the same. Some sacrifices are simply necessary for the good of all men (and motorcycles).
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- stonemaster
- Visitor
23 Jul 2010 19:33 #385105
by stonemaster
Replied by stonemaster on topic air jet removal, 29mm
use some PB Blaster or some Liquid Wrench penetrating oil first and + 3 on the screw driver alteration
